Discussion topic: Amber lights voice and internet
Message posted on 03 Feb 2025 01:52 PM
We have Sky full fibre. Amber lights on internet and voice - been happening for a few months now, have had an engineer from Openreach who checked everything thoroughly, could not find a fault even though the amber lights actually happened while he was here. He ordered a new hub for us from Sky which we have fitted but still getting the same problem, internet drops every day constantly. Have also phoned Sky again and told to unplug everything, wait for an hour and plug back in, done this several times, still getting the same problem.
Message posted on 04 Feb 2025 08:14 AM
Re: Amber lights voice and internet
Hi there, @donnyosmond. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 17 Mar 2025 05:59 PM
Broadband constantly dropping
We have had problems with broadband dropping for four months. We have had NUMEROUS phone calls to Sky, Openreach visit, new hub, new Ethernet cable. All to no avail. Still drops,out EVERY day. Now we do T even have two amber lights, we have two green, one amber and the internet light is out completely. I don't want to waste any more time on this and will need to cancel everything I have with Sky if not resolved right NOW!
Message posted on 17 Mar 2025 06:05 PM
Re: Broadband constantly dropping
@donnyosmond
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services so it won't be resolved immediately.
