Discussion topic: Adding a wireless security camera to my white Sky Router
This message was authored by: Gaza55
I'm looking to add a wireless outdoor 2.4mghz security to my outside wall.
Will it connect wirelessly and remotely to my white Sky box without any hassle
Re: Adding a wireless security camera to my white Sky Router
@Gaza55
You would need to temporarily disable 5ghz on the max hub and then if you are using a pc or mobile app to set the canera you would also need to turn the wifi off so that when you turn it back on it will have forgotten the 5ghz.
See below
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
@Gaza55 Hopefully the wireless wi-fi signal from the sky Hub also reaches where you need it, getting signal out is not that easy!
