Discussion topic: 900 gigafast speed
This message was authored by: wills63
900 gigafast speed
If I check my speed using the sky speed checker it shows I am getting 900+ but if I check using okai Speedtest it shows 450 and if I use fast.com it shows the same. Also in the last couple of days the broadband has gone off at virtually the same time(4.45pm) for a couple of minutes and the max router re sets itself.   Anybody have any ideas
Re: 900 gigafast speed
@wills63 If you are wireless wi-fi speed testing then expect it to be anywhere, and the Hub should not be blipping off/on, but could have been something going on Fibre/Exchange end, just keep an eye on that! Best to look at the ONT when things are going strange!
