09 Feb 2025 04:45 PM
My router can't find my sonos play 3 speaker, so I can't add it to my network to control via my phone. I do not know what gigaherz my box is working on, which I believe makes a difference.
09 Feb 2025 05:18 PM
Which hub do you have?
09 Feb 2025 05:26 PM
Sky Broadband hub
09 Feb 2025 05:31 PM
Sonos tend only to work on the 2.4ghz wifi band
To seperate the wifi into 2 seperate wifi:-
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Also if using a mobile app to install the speakers make sure you assign to the newly created 2.4ghz frequency
09 Feb 2025 05:34 PM
Thank you for your response. By some fluke, after 6hrs I have just established a connection.
