2
This discussion topic has been answered Discussion topic: Add private wifi network
This message was authored by: PacoR
Has anyone able to create more than the default two wifi networks? I would like to create different ones for usages like guests and other gadgets.
I can't even change the name of the WiFi network and can't differentiate between 2.4GHz and 5GHz.
I have the white router.
Re: Add private wifi network
That's never been possible on any Sky Hub model.
Cannot be done on the white Max Hub.
@PacoR simplest way to achieve your aim is to buy a third party WiFi system in access point mode which offers the services you require and use that in placecof tge Sky b]hub's wifi.. My cheap Deco system offers a guest network as do many other systems.
