Discussion topic: Activation code
This message was authored by: Raj187
Activation code
Can I have activation code
Re: Activation code
This forum is primarily customer-to-customer help, you're not talking to Sky support
You'll need to explain further
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Re: Activation code
@Raj187
Are you asking for a Sky sim activation code ?
Avatar for Raj187
Re: Activation code
No activation for broadband
Re: Activation code
@Raj187
What date did Sky give you for the activation, was it today ?
Avatar for Raj187
Re: Activation code
Hi
Avatar for Raj187
Re: Activation code
Hi activation fate 20th October 2025
Avatar for Raj187
Re: Activation code
How do I get activation code and when on the day do I get code?
Re: Activation code
@Raj187
You haven't answered the question:
What do you need an activation code for ?
If for broadband then there isn't one so if you activation is on the 20th then it should happen sometime tomorrow.
Re: Activation code
@Raj187 there are no activation codes required for any Sky Broadband services. The activation is done remotely by the network operator who are probably Openreach.  Customers simply connect the Sky hub to the line as explained in the leaflet in the hub's packaging and it will connect as and when the service goes live. The hub is preprogrammed to connect.
If you want to connect a third party router that will need to be programmed to connect the steps required vary by the service you are connecting to but there sre no specific account nsmes or user passwords required. If tgst applies post the make and model of router you plan to use, whether the service is full or partial fibre and whether you are in the UK or Ireland.
