Discussion topic: 5ghz or 2.4ghx
Message posted on 17 Sep 2026 02:28 PM
5ghz or 2.4ghx
Hello
my sky Wifi box shows
Message posted on 17 Sep 2026 02:30 PM - last edited: 17 Sep 2026 02:31 PM
Re: 5ghz or 2.4ghx
As posted by @jamesn123
Note that this process does not apply to the new (white) Max Hub
So to split the two channels you need to go to your router config page which can be found by typing 192.168.0.1 into your web browser.
To access the page, you'll need;
username: admin
password: sky OR your WiFi password
- Select wireless from the navigation bar and scroll down a little and untick the 'Synchronise 2.4GHz and 5GHz settings'
- Scroll to the bottom of the page and hit apply.
- Once the page reloads you need to go to the 5GHz wireless settings page on the sub navigation bar below where you click wireless before
- In the 5GHz section you want to go to the box called 'Name (SSID)' and add something like 5g to the end of the current name
- Scroll down and hit apply
- Then on any wireless device you should now see two networks. One network will be the same name as usual and will be 2.4GHz band and the other will be the usual name with 5G on the end (Or whatever you typed). Connect any 5GHz capable device to the 5GHz network and see if it works correctly. The WiFi password should be the same if you havent changed it.
Message posted on 17 Sep 2026 02:35 PM
Re: 5ghz or 2.4ghx
Thank you Timmybgood for that info I will try it later and any probs will let you know once again many thanks
Message posted on 18 Sep 2026 03:36 PM
Re: 5ghz or 2.4ghx
Hello timmybgood
your information worked all I ask is can I synchronise 5ghz and 2.4ghz after I have installed my video doorbell on 2.4ghz and will it still work
once again many thanks for your help I am a 70 yr old pensioner and I really appreciates it
ps all this new tech confuses me !!!!!!
kind regards
tony
Message posted on 18 Sep 2026 03:40 PM
Re: 5ghz or 2.4ghx
Hello timmybgood
kind regards
scotpics
Message posted on 19 Sep 2026 05:32 AM
Re: 5ghz or 2.4ghx
@Scotpics in most cases yes you can synchronise the two bands and the devices should stay connected.
