21 Oct 2024 05:04 PM
Good Afternoon
My router is a few months old and i presume is 5ghz how do i activate 2.5ghz please any help would be greatly appricatied.
PS hope this reaches an actual human being !!!
Regards
Matthew
21 Oct 2024 05:05 PM
Which hub do you have?
21 Oct 2024 05:09 PM
Hello Cookie
Model: SR213-02-UK-wht is this the correct one ?
Try the link below to either seperate the wifi for two distinct ssids for the black hubs or
Temporarily disable 5ghz to allow 2.4ghz devices to connect
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
21 Oct 2024 05:11 PM
@Matt0101 wrote:
Hello Cookie
Then you need to disable 5ghz temporarily so 2.4ghz devices can connect
21 Oct 2024 05:19 PM
Which login details is it please my sky id (app) or login details on the router ?
21 Oct 2024 05:22 PM
For the max router sr213 you use the my sky app so i don't think there are any log in details. The process should be in my link above just toggle down to the white sky max procedure
21 Oct 2024 05:22 PM - last edited: 21 Oct 2024 05:23 PM
Username is admin, password is the WiFi key (unless you've changed this)
Edit: oops, not for the 213 (Max Hub)
