7
This discussion topic has been answered Discussion topic: 20+ Freeview channels have disappeared. I have turned wifi of/on reset the TV Channels
This message was authored by: Zouch1
I have turned the broadband off and back on. I only have 86 programmes on the Digital channel which I have reset several times. Previously, for example Channel 21, 5USA was pixelated but is no longer there. There are 20+ channels missing
This message was authored by: JimM1 Answer
Re: 20+ Freeview channels have disappeared. I have turned wifi of/on reset the TV Channels
@Zouch1 Re-tune the TV again, the channels may have had a transmission problem from the Mast wherever that is in your area!
@Zouch1  Freeview is delivered via an Aerial and not your broadband, so restarting your hub is a pointless exercise.
Can you confirm you do mean Freeviw or are you receiving your channel via a nother service?
@Zouch1
Freeview (broadcast) or Freeview Play (streaming)?
Avatar for Zouch1
On my TV it states that I have 86 Digital channels . 20+ are missing
@Zouch1  If this is freeview via an aerial connection this has nothing to do with Sky broadband, or any broadband provider.
Avatar for Zouch1
Thank you, just have done and there was a problem so all sorted now
@Zouch1 Happens from time to time and especially in a bad weather day, then a re-tune drops all the poor signals as the TV cannot get them so ignores them!
