Discussion topic: Sick to death
Message posted on 10 Nov 2025 11:52 AM
Sick to death
I am sick to death of the WiFi
Barley works and goes off all the time
Message posted on 10 Nov 2025 12:27 PM
Re: Sick to death
@CatherineM2
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
