5
Discussion topic: 2.4 and 5ghz won’t split
This message was authored by Wanderers1958 This message was authored by: Wanderers1958
Followed previous instructions to un sync in router settings and rename but when I click apply I get a page not found error
This message was authored by Highlinder This message was authored by: Highlinder Answer
Re: 2.4 and 5ghz won’t split
@Wanderers1958For some reason the router settings does not like IOS are you trying to use Safari on the iPhone. Are you able to use another browser on the phone like chrome?
@Wanderers1958Which type of device is this being done on and which browser are you using to do this task?
Wanderers1958
I'm trying on my iPhone at the moment as the only laptop I use is my work one
Wanderers1958
Perfect-that's worked! Still can't get the smart plug to connect but that's another issue! 😂
@Wanderers1958Okay, glad it worked out for you on the Split.
