Discussion topic: 150mb FTTP not performing throughout property
This message was authored by: fjw79
Good Morning,
Your WiFi speed test to the hub indicates everything is ok however on my mobile “fast.com” test it sYates I'm only getting 27mb download upstairs.
I have booster connected up stairs too. Do I need to reconnect it?
Re: 150mb FTTP not performing throughout property
@fjw79
Sky's quoted speed is via an ethernet cable, not WiFi. Having a booster will increase coverage around your home but may actually reduce the overall speed due to the way it boosters the signal.
I am NOT a Sky Employee
Avatar for fjw79
Thanks for the info. I'll phone them this evening.
If I use fast.com to check right beside router is says 60mbs on average. I asked my Dad who has BT 150mb fibre in the same town to do the same and his was reading 150mb. Both Wi-Fi.
@fjw79
Generally BTs router is superior to Skys in terms of raw performance, additionally the location/house construction/neighbouring WiFi impacts the results quite a lot so its almost impossible to fairly compare two different locations.
