4
This discussion topic has been answered Discussion topic: 1 red light on router and nothing else
This message was authored by: Rowanstevens
My router stops my internet resorts to just one red light and no other lights and nothing changes if I unplug and plug back in or if I reset
This message was authored by: jamesn123 Answer
Re: 1 red light on router and nothing else
Hi @Rowanstevens
Which hub do you have?
I am NOT a Sky Employee
Hi @Rowanstevens
Avatar for Rowanstevens
Level 0 icon
Unsure it's sky q I think
@Rowanstevens
You can check the model number on the sticker, or refer to this guide with the pictures of the hubs and the names.
@Rowanstevens You may wish to also follow and use the hub lights reference also, when you click will take you to testinfg if you have an issue.
