Discussion topic: 0.5 mb speed
Message posted on 21 Nov 2024 09:04 PM
0.5 mb speed
My internet is running at just 0.5mb.
i have done all of the recommended trouble shooting steps and no progress.
please sort this as a priority.
Message posted on 21 Nov 2024 09:07 PM
Re: 0.5 mb speed
Dan7777
bear in mind you are posting in a User forum, not a support section where you log a support call and they get back to you.
You need to get on the phone, ask for your minimum guaranteed speed and start asking for money back
Good luck!
Message posted on 21 Nov 2024 09:09 PM
Re: 0.5 mb speed
@Dan7777 This is a customer helps customer community nothing will be sorted on the back of a forum post, no one at Sky will know who you are or your account details.
For the community to help please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Message posted on 21 Nov 2024 10:44 PM
Re: 0.5 mb speed
Message posted on 22 Nov 2024 10:11 AM
Re: 0.5 mb speed
Appreciate you are out of yout depth there.
How did you get to conclude that your speed is 0.5mb? Where did you measure that, How did you do that? the more details you add, the more we are likely to pick up on the cause.
The information that you posted, shows which devices you have connected to your WIFI network and further complicates.
Are you able to power down all those devices (unplug them from the wall outlets!) and then use a laptop/pc to connect to your router. (ie take the whole WIFI aspect out of the equation and have a power and phone line go into your router, then 1 network cable to your computer)
