4
This discussion topic is read only This discussion topic has been answered Discussion topic: white dot next to recordings
This message was authored by: royza
Hi, I am having problems with multiple recordings. I am unable to see a white dot next to recordings I have watched and have to try to remember which ones I've seen. Any ideas please?
Re: white dot next to recordings
Hi @royza
If you go to Recordings  - Sort by - A to Z you will see the white dot against unwatched.
Same in Recordings - Manage - Disk Space
Locked
Hi @royza
Avatar for royza
Level 0 icon
Hi oldfella, thanks for that. I thought it may be me being a dummy!
No problem @royza
The white dot used to be listed against Recordings in the Most recent section but Sky in their wisdom removed it.
You can  look at the Recording tiles  in this section and watched recordings will show the Light Blue progress bar underneath if watched (provided you don't watch it completely to the end )
@oldfella wrote:
No problem @royza
I had forgotten that they left the white dot the other sections 🙂
Not too sure why they decided to remove it from the most recent - although I do think it was slightly unreliable
Locked
