Discussion topic: volume button on remote not working. changed batteries. still not working, bought new remote, still
Message posted on 10 Jun 2020 06:41 PM
Re: volume button on remote not working. changed batteries. still not working, bought new remote, st
@paigebluepoppy wrote:
Sky sent a message saying they upgraded my system on Monday and since then my volume is all messed up. The volume on my Sky remote does not light up Red anywhere; the rest of the remote is fine.
I'm being forced to run my Samsung TV at 65 where it's normally 14! And if I use any Streaming apps or DVD I have to mute prior to usage or fear blowing speakers! Ugh.How do I fix this ? Please ?
Did your TV not come with its own remote? Your not forced to use the sky remote for TV sound
Message posted on 10 Jun 2020 07:59 PM
@paigebluepoppy the system upgrade can't be causing this. You could try resetting the remote by programming it with code 999, then programming it again with the correct code for your TV.
Message posted on 03 Oct 2020 03:44 PM
Having the same problem and changed batteries and about to buy a new remote! - I now have audio description stuck on my tv and can't see the football scores going through. Daren't mess around as I am watching sky sports.
I think I will phone sky and ask them.
sorry I am no help
Message posted on 23 Dec 2020 02:18 PM
Recently upgrade sky q box to HDR sky qbox
so accompany new r/c volume button +~ not functioning and mute as well it working let me know what I suppose to do
Message posted on 23 Dec 2020 02:20 PM
You've posted in the Sky+ forum. Someone will be able to help on the Sky Q forum.
Message posted on 31 Dec 2020 02:40 AM
I had similar problem to OP after installing sound bar - volume button on Sky remote had no effect even when I disconnected soundbar and used tv speaker.
Knew that my code was correct from original setup (1451).
In the end did your trick, unpaired it by setting it to 999 and reset to 1451 and volume button works correctly now. Thanks
Message posted on 24 Feb 2021 04:41 PM
hi dont know if anyone is still looking at this but i followed the link to reprogram the remote and it worked for me, so thanks for the info cheers derek
Message posted on 20 Apr 2021 08:43 PM
Thanks for this!! The factory reset did it for me
Message posted on 27 Aug 2021 03:31 PM
@Anonymous wrote:
When I press volume button on remote, red light does NOT come on at box. Changed batteries, still no red light, bought new Sky Remote, still no red light on box...all other buttons working ok.
When you press the volume buttons the signal goes directly to your TV and not to the Sky box
Message posted on 04 Sep 2021 10:12 AM
@caesarome @Thank you so much!! This resolved my issue after much battery changing and reprogramming and searching. You are a star ⭐️ 😛 thank you!!
Message posted on 04 Sep 2021 10:26 AM
Actually, scrap that, it's not fixed it at all 🤣
Message posted on 19 Oct 2021 10:04 PM
Volume button on my remote is not working
Message posted on 19 Oct 2021 11:15 PM
Have you programmed your remote with the correct code for your tv?
