This discussion topic is read only Discussion topic: very slow internet, Please Help
This message was authored by: Cezar32
Hello. From Friday, my internet is very slow, the speed via wifi is about 2mb and 8mb via cable. the upload speed is probably ok because it is 20mb. I reset my router, did everything as per sky.com manual and still nothing. I have Sky Broadband Superfast. please help
Locked
Re: very slow internet, Please Help
@Cezar32
Can you post your router stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Also are you speedtesting via wifi
@Cezar32  If you post your router stats the forum will be able to help, this link explains how to get them  https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717
Please be aware when posting images they will need to be approved by the forum so won't show straight away.
Avatar for Cezar32
Router Statistics
System Up Time: 00:41:38
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 125662 129242 0 10616 5742 00:40:27 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 24497 19176 0 1490 0 00:40:00 WLAN (5 GHz) Up 138054 126207 0 530233 38638 00:39:40
Broadband Link Downstream Upstream Connection Speed (Kbps) 79891 20000 Line Attenuation (dB) DS1:3.9    DS2:10.2    DS3:16.7 US0:2.4    US1:8.1    US2:12.4 Noise Margin (dB) DS1:6.3    DS2:6.2    DS3:6.2 US0:13.0    US1:9.9    US2:9.8
Poll Interval:
Seconds (at least 3s):
I tested via wifi and cable
Avatar for Cezar32
@Cezar32  Your line speed is 79mbps download, if you test over ethernet you should should get close to that assuming no other app, devices etc are consumi g any data.  Have you tried using fast.com to speed test, what are the results?
You do need to ensure nothing else is being used such as xbox/ps4s, netflix, prime etc as they will be consuming data.
Avatar for Cezar32
on fast.com via wifi is only 2mb and via ethernet 8-10mb
@Cezar32Looking at those router stats, did you run the speed test when you rebooted the router or before for the Ethernet test?
@Cezar32
Your stats show ethernet hasn't been connected for at least 40 hours. If you are testing via wifi on a mobile device then its likely on the 2.4ghz band which is slow
Avatar for Cezar32
I tested before resetting. I always had a minimum of 50mb via wifi and now only 2mb. something must be wrong if a few days ago it was ok.
@Cezar32  Wifi interference could be the cause.
Could you do a speed test over ethernet please.
@Cezar32Have you tried to change the Wi-Fi channel if you live in a built-up area it be other networks around you are causing issues. But if that is not the case then how long have you had the router you got given by Sky.
Avatar for Cezar32
a few days ago I did not have any interference and now I have?
Avatar for Cezar32
I have this router for about 2-3 years
@Cezar32  Yes, it can happen, wifi can get interference from a number of sources. Simply because it was ok one day doesn't mean it would be the next day, that is how wifi works, if you use a wifi analyser app on your phone you will see how many wifi signal are showing and some are probably clashing on the same chanels.
Locked
