This discussion topic is read only Discussion topic: archer tp link 2100 vr600 replace sky sr203
This message was authored by: stevecook007
i connected the ac2100 sucesfully to sky replacing the sky sr203, what im trying to do if at all i need to not sure but how or do i need to configure ipv6 ? any advice appreciated.
and is it ok that the dsl say connected but disabled ?
what i trying to do is now its connected working is carry out tweaks to get the best from the router
thanks in advance
steve
Locked
Re: archer tp link 2100 vr600 replace sky sr203
@stevecook007
Enabling IPv6 on the router should be fine and if its already connecting to the Sky network via IPv4 it should fetch an IPv6 public address on its own. Alternatively you may be able to connect it via IPv6 PD
I am NOT a Sky Employee
Avatar for stevecook007
Thanks yes ipv4 runs fine just trying to learn to tweak settings loads better than sky just pitty can't get skyQ box working 🙈😂
This message was authored by: Skull+Treaty
@stevecook007
Did you manage to turn the IPv6 on, in the router?
"Sometimes, the only choices you have are bad ones, but you still have to choose"
Not sure how to check if it's working I have ticked the enable. Still learning about tweaking this router but speeds are awesome
This message was authored by: jackmalanak
I've used the following settings to configure IPv6, initially on a VR900 and over the last year or so on a VR2800.
So I'd imagine the layout on your VR600 to be very similar.
Once logged into the Router
1 Click on Advanced
2 Then Network
3 Then Edit the Wan Interface
4 Then Enable the IPv6 check box
5 Addressing Type needs to be SLAAC
6 Click on OK at bottom of page
7 Then click on LAN Settings
8 DHCP Server
9 Click on IPv6 Radio Button
10 Address Type should be RADVD
11 Prefix Type is Delegated
12 Click on Save, then Log Out
IPv6 Should now be fully working  😀
thanks for that followed it every step noticed i hadnt changed the RADVD option so i think i have done it not sure if can test it to be sure.
great set up cant get over im getting full speeds all round house now just pitty skq box wont stay connected tho but think ill just stop using skyq and stream now having full sppeds 🙌 thanks for advice let me know if any other tweaks need doing 🤔👍
steve
Locked
