This discussion topic is read only Discussion topic: broadband speed
Locked
Avatar for Geeza3456
Level 2 icon
This message was authored by: Geeza3456
Re: broadband speed
well well well It looks like im on to something here as Im clearly not the only one having issue..and as for the info about routers etc thanks but I like the others are 2m away from my sky router and getting 39mb/s on anyone one of the speed test sites and mysky site saying im getting 71mb/s...something is not correct here
This message was authored by: Mark-Br
Re: broadband speed
@Mark-Br wrote:
Why is the Sky speed test showing a different result from the online speed tests?
They are measuring different things. Speeds that you see on Sky.com or My Sky app are measuring line speeds received by your Sky Hub. Whilst your speed test apps are measuring throughput (usually over WiFi) which can be affected by a whole host of factors - including environmental and hardware.
Our Broadband Speeds explained page offers more info which may be useful 🙂
Line speeds vs Throughput speeds
Mark
Community Manager
Level 2 icon
Re: broadband speed
You have said speed can be effected with different things, walls etc how can this be the case when im at 2m away from router...whats coming in is not whats coming out
This message was authored by: ChalcotLondon1
Re: broadband speed
Thanks for that Mark,  but that really doesn't help at all.
So i am to just put up with it until my contract end date and then move broadband suppliers? Or can Sky be more proactive and help?
Re: broadband speed
These steps may help to help boost WiFi signal around your home. https://www.sky.com/help/diagnostics/bb-speed/how-to-improve-your-broadband-speed-all
Also, our latest Sky Broadband Hub provides our best WiFi signal https://community.sky.com/t5/Broadband/Can-I-get-the-new-Sky-Broadband-Hub/m-p/3061618#M136450
Mark
Community Manager
Re: broadband speed
@Amanser  what type of device are you using to do the speed test with and is it wired or on WiFi?
Level 2 icon
Re: broadband speed
So i have to pay £5 PM more to get this new hub and garenteed speed..really I thought thats what I had signed up for few month back !!
Re: broadband speed
@Mark-Br wrote:
What is my guaranteed speed?
The good news is that your 70mbps line speed is comfortably above your guaranteed line speed of ~60mbps - guaranteed speeds will vary from home to home.
Your Wi-Fi speeds will not be guaranteed unless Sky Broadband Boost is part of your subscription, it includes a WiFi Guarantee and upgraded hardware, but from what you've described, that doesn't apply here as your 40-60 mbps WiFi speeds exceed the guaranteed minimum we'd offer
Ah, there are two types of speed guarantee.
Your Guaranteed Minimum Download Speed references line speed and from what has been described, you were guaranteed ~60mbps and are receiving 70mbps.
The WiFi Guarantee is a minimum of 3mbps in every room in your home which your speeds already exceed. We have found that our new Hub offers improved WiFi, but if you made the decision to invest in the new Sky Broadband Hub there would be no guarantee of improved WiFi speeds.
Ultimately, the internet and WiFi are two very different beasts - moving data 3,000 metres through glass cables is far easier than 10 metres through the air.
If there are specific questions around how to improve your WiFi experience, I recommend getting in touch with our contact centre who will have access to all your information. 🙂
Mark
Community Manager
This message was authored by: Amanser
Re: broadband speed
@Highlinder I have ran the test on my Samsung s20+ and also on the company laptop I have. WIFI connection on both as I have no way for a wire connection.
I have also tried to download a game I purchased on the PS4, a 45gb game told me it'll take 70+ hours to download. I have just retested on the laptop with just that running and got 4mbps down and 2.8mbps up.
Re: broadband speed
So all devices are on WiFi and none are hardwired at all?
Re: broadband speed
Yes they are all WiFi. Silly me thought in 2021 I could be wireless with decent speeds. Although given I did a speed test on the 25th June again on my mobile and got 67.6mbps, thats my bad.
Re: broadband speed
You see the technology is there, but what is the make up of your house. Sold walls stop the signal getting through and other factors. Also have to take into account the placement of the router, and if there is a lot of other people around you that also have their WiFi.
Re: broadband speed
As I mentioned if I stretch my right arm out, I'll be touching the router. All that is between me and the router is fresh air.
This message was authored by: JPR007
Re: broadband speed
@Amanser It maybe fresh air, but it could well be highly congested airspace.
Have you split the WiFi bands on the router or are they synced? It maybe your devices are clinging to the 2.4GHz network rather than using 5GHz which is significantly less crowded and can enable much higher data rates.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Re: broadband speed
I have no idea to do anything you just said
Locked
