Discussion topic: broadband speed
Locked
Geeza3456
This message was authored by Geeza3456 This message was authored by: Geeza3456
Re: broadband speed
what can be done ??
Re: broadband speed
Are these drops in your connection happening often? You need to report them if the broadband test is not showing an issue on the line, this can happen. So that Sky can do further tests to determine what the issue is that is causing the line to disconnect.
Geeza3456
Re: broadband speed
I have no clue how offen they are happening, Tbh its the first I heard of it ..will this cause slow speeds ??
Re: broadband speed
You are getting 70Mb down/ nearly 18Mb up, that is not slow. What does it show when you run the broadband test?
Geeza3456
Re: broadband speed
40 to 50 max
Re: broadband speed
Which test are you getting those speeds from?
Geeza3456
Re: broadband speed
varous online speed checkers all more or less say the same
Re: broadband speed
Have you tried the broadband test from Sky to see what line speed you are getting into the router and any possible issues?
Geeza3456
Re: broadband speed
Yes ... thats my issue,  Sky site and test says 70mb/s, but thats them,  but inan around my house  it is not, its more like 40/50mb/s at PC within 2m of router ..whos or what is telling the truth ???????
Re: broadband speed
When you run the Sky broadband test, you are testing the speed coming to the router. When you use any other test, that is testing to thedevice you are using.
Now as an example, I am on an 65 down 20 up connection. I just tested my own connection using the Netflix speed test and it told me I was getting 55Mb and this is on a wired connection.
You are never going to get the full speed it says on the Sky broadband test, there is always a percentage that is lost in overheads.
Geeza3456
Re: broadband speed
My problem is when I tested it a few month back i got on same speed test 61/65 Mb/s at PC,  that was when I first got the Q box installed and upgraded to fibre max,  like I say a few month back, but it has slowed over time with nothing added to system,  something is not correct as how can I have 60 plus then down to 40 for no reason yet Sky say garentee min 60 mb/s, yes I did at first,  but now not ??? ...And nothing can be proven as sky say 70 mb/s on there site,  and I say actual is 40mb/s and everyone saying yep thats the way it is ...I think the garentee of min 60 mb/s is rubbish no way to prove it..
Re: broadband speed
@Geeza3456What does it say you minimum is supposed to be in the broadband test and what you are you supposed to get in between? This information can be found when you have ran the broadband test under " Tell me more about my connection ".
Geeza3456
Re: broadband speed
Well sky garentee me for my fee..min 60mb/s otherwise a refund is offered for days below ... yet i cant prove it that im well below,  at 40mb/s ish,  on mySky site there broadband checker says 70mb/s is being deliverd every day perfect ...but its not what im seeing here theres a con somewhere I feel,  there was 61mb/s at first and now im at 40mb/s...So whats changed ..nothing this end ...I understand some loss but if im getting sent 70mb/s and I got 60mb/s at PC theres the 10mb/s loss which I can accept,and was happy,  but now @ 40mb/s this is beyond @ 30mb/s down...And im stuck with them for 18months and nothing can be done
Re: broadband speed
Could you please run a test via the site below, I know there will be some loss, but it will give us a better idea what is going on. If you can do it on a wired connection if not on WiFi.
https://fast.com/#
Geeza3456
Re: broadband speed
Results below
Your Internet speed is
42
Mbps
Show more info
Locked
