This discussion topic is read only Discussion topic: Upload Speed Dropped Drastically
This message was authored by: Sgb1
We had Sky UltraFast installed yesterday and the results were as expected (1st picture)
All morning the upload speed has droppped drastically resulting in connection drop outs (2nd picture)
Restarted the router a couple of times this morning, and disconnected devices to see if there was any improvements
274196338_1152290529016534_5727444220364143561_n.jpgCapture.PNGRouter Stats.PNG
Locked
Re: Upload Speed Dropped Drastically
@Sgb1On ultrafast we are unable to see the speed that a user gets, could you run a test from the link below, let it complete and take a screenshot.
https://fast.com/
@Sgb1  Are you doing the speed tests over ethernet?   What results do you get with fast.com
Avatar for Sgb1
All of the tests were completed over wifi
Fast results;
Avatar for Sgb1
@Sgb1
Any chance you can complete the tests over ethernet instead? Hard to say when its done over WiFi.
I am NOT a Sky Employee
Avatar for Sgb1
Unfortunately not, as the router is downstairs and my PC is upstairs.
I do have Powerline Adapters, if that would be a better test?
@Sgb1
Probably slightly better yeah but still hard to prove any fault to Sky without showing an ethernet test
Avatar for Sgb1
Hi @jamesn123
My partner brought his work laptop home.
Please see ethernet speed test from Fast
That is very poor.
Assuming there is nothing connected to the hub that might be doing some sort of upload?
Avatar for Sgb1
Nothing connected. Router has been reset again, so only 1 device connected and still the same result.
Day of install the Upload was 70mbps, now as you can see its awful.
@Sgb1
I've flagged your post to Sky. Look out for an email or message on the forum
This message was authored by: Lisa-P1987
Thank you for escalating this. We have now sent Sgb1 an invite to chat 🙂
Lisa - Sky Tech Team Expert
Locked
