732
This discussion topic is read only This discussion topic has been answered Discussion topic: Stream remote completely unresponsive
Locked
This message was authored by: Mark-Br
Re: Stream remote completely unresponsive
@JessH13 wrote:
I haven't been on here for ages just been losing my mind in irritation at the constant emails about it 😅
Hi Jess,
If you scroll to the top of the page/thread, you should see an 'Options' dropdown.
Hit that and choose 'Unsubscribe'
That will stop emails to you about this thread.
DesktopDesktop
Mark
Community Manager
This message was authored by: ditditdot
Just ordered a remote from Amazon if it works fine if not then we play the replacement game to begin
This message was authored by: Zuby
My sky stream Remote control  completely NOT responsive at all , spend last few hours on all the solutions , no response from sky either
Just joined SKY as a new customer
Got my box only  few days ago
So frustrated... Big mistake to join sky
This message was authored by: lohr
Cancel your subscription Zuby and send the kit back free of charge.
This message was authored by: Clivers
Call Sky and ask for the cancellations dept, usually no or very little waiting.
Sky have admitted it is caused by faulty Remote controls, poor manufacturing.
This message was authored by: Bordonbert
Have a look at the thread titled "Got that intermittent faulty remote problem? Try this - CAREFULLY!"
I managed to find the cause in my own remote and fix it permanently.  If you look carefully it is pretty obvious what is happening to cause it.  I'm sure most people could get round the issue by applying this.
_____________________________________________________________________
[Just ask! A moment of embarrassment is better than a lifetime of ignorance.]
This message was authored by: Tristan3147
Just went to change channel land nothing completely dead changed the batteries twice with new ones still dead
Just gave the remote a slight twist with both hands,now working again
This message was authored by: PaulN66
Try pulling the positive end of the battery connectors up a little you will probably find it works fine. The problem appears to be bad connection with the batteries. Several people have suggested the same thing. It worked for my remotes.
This message was authored by: Old+faithful+47
Re: Sky puck remote not working
Hi
my sky puck remote consistently isn't working. I've replaced the batteries and tried pressing 7 and 9 then 4 and 6 then 1 and 3 but not working
thanks
This message was authored by: motlotlegi
Hi there,
My puck remote arrived at my mail box but will not allow me to set up my puck. The remote does not even have any backlight even after changing batteries.
Kindly assist me as my billing will begin regarding of whether I have activated my device or not.
Regards
This message was authored by: Craigarty
Stream remote has died when battery changed
Had sky stream for about three weeks now, remote has shown it's battery levels are low. Changed two new Kodak batteries, worked for one second and stopped, no light on remote, nothing. Batteries are good. More dodgy Sky products, sounds like a common fault on the threads. Sent 3 Glass back before cancelling, due to issues with the sets. Phoning Sky in the morning, I thought this would have been a good product.
This message was authored by: abbiepal
remote on sky glass
so ive just got my sky glass and i am connecting my remote. however it is going back and forth with the connecting your remote and your remote is not connected. i have unplugged by the mains. tried again. unplugged by the mains and my router. still not working.
tried connecting a different remote it connected then i went to the home page and then it went to the connecting your remote screen when i never pressed 1 & 3
Please can someone help.
I JUST WANT TO WATCH TV IN BED!
Re: remote on sky glass
@abbiepal
I've moved your post from the Sky Q to the Sky Glass board.
Locked
Answered - Go to Answer
