Discussion topic: Stream remote completely unresponsive
Message posted on 03 Dec 2022 10:45 AM
Re: Remote dead
@Vincentcat have you tried holding it in both hands and twisting it? Like you're wringing out a cloth! Failing that buy a Sky Q remote from Argos and use that until you get a replacement.
Message posted on 03 Dec 2022 10:51 AM
Defective remote control.
I'm at my wits end with Sky Streams remote control. Sky have already replaced it once and now have the same issue.
I have been changing the batteries in the replacement once a week, and now even with fresh batteries nothing happens.
Now stuck paying for Sky Stream that I cannot use at all.
Can anyone assist?
Message posted on 03 Dec 2022 11:04 AM
Re: Stream remote completely unresponsive
Had the Stream for just over 1 week. While setting up, message on screen - Battery low. OK, sometimes this happens.
Over the next 4 days, changed the battery 3 times. They dont last more than a day, just used for Switching on and occasional channel changes.
Rang tech support, stated igonore message on screen. Pointless response, as remote dead within 24hours.
Thought I'll check how much current is being used while remote is sitting idle. 4mA and fluctuating continusoly. Explains why the batteries dont last. The remote should be sleeping, looks like its not, hence the problem of batteries being drained within 24hours, pointing towards the Remote control programming or hardware issue.
Next issue: Sky puck will not wake up, if the network is wired. Was told to disable wifi, does not make much difference. So, when wired network, the puck is unable to wakeup when requested to wake up. Just get the SKY for few minutes and shutsdown. Works better on WifI.
Message posted on 03 Dec 2022 11:08 AM
Re: Remote dead
Just a bit rubbish after 2weeks have a weekend off load of money so begrudgingly don't really feel great about paying for a remote but looks like the only option apart from ransacking the local sky booth and the shopping center
Message posted on 03 Dec 2022 11:15 AM
Re: Defective remote control.
Hold it in both hands and give it a twist - call sky anyway and book a replacement there's a bad batch going around
al else fails a sky q remote will pair up
Message posted on 03 Dec 2022 11:28 AM
Yes, while I totally get that we shouldn't have to, if I was still stuck with a dead remote right now (considering I'm already on #2) I'd be sourcing a Sky Q remote rather than waiting for Sky to get their finger out.
Like I say, shouldn't have to, but thats what I'd do.
Message posted on 03 Dec 2022 11:41 AM
Oh, and something else that's just crossed my mind that might possibly help those still struggling -
I discovered there is kind of "in between" state, between the Remote being dead, and working.
In this.state,.it's as if the Remote is simply undervolted, as if you are trying to use it with nearly dead batteries, so.you get "low battery" pop ups on the screen etc.
Now during my tinkering I discovered the following...
While in this state, I could operate the puck perfectly, no problems at all, right up to the point where I touched the volume buttons,. At which point the remote would either slow to a halt, or stop working completely.
Before I discovered this I assumed my remote was working for a few minutes then dying... But the reality was it would work for as long as you like, as long as you don't touch those volume buttons. It doesn't matter if you have set the control up to control your speakers or TV or not.
So if you are in this limbo, try repairing the remote, Skip the "Control your TV" section, and see how you go WITHOUT TOUCHING THE VOLUME OR POWER CONTROL as it seems it was the IR functions that were pushing my particular remote into a coma.
Absolutely not Ideal I know, ....but at least you might be able to actually use your Stream until it's sorted properly.
Hope this helps someone.
Message posted on 03 Dec 2022 11:43 AM
Just for point of reference I had my sky glass and a puck back in April and never any issues with the remotes - in fact the remotes are a lot better than the q remotes
I suspect that when sky ramped up production ahead of the stream release the manufacturing process may have run into some difficulties.......
Message posted on 03 Dec 2022 11:55 AM
Just installed a second puck and the remote works 😱!!
Message posted on 03 Dec 2022 01:02 PM
Re: Sky puck remote not working
I am having the same issue. My pick remote isn't working at all. Its my first ever sky product, I was so excited and now I can't even use it (and its not cheap). I have the Sky Puck and I have changed the remote batteries and I have tried the holding down of buttons etc but none of it is getting the remote to work.
Message posted on 03 Dec 2022 01:08 PM
@Ldown45 Have you tried @AntInBristol 's 'twist trick' as mentioned in this thread? https://helpforum.sky.com/t5/Glass-Stream/Stream-remote-completely-unresponsive/td-p/4128756/page/32 - it's helped many on here breathe life into dead remotes.
Message posted on 03 Dec 2022 02:36 PM
@Mjstrong wrote:Oh, and something else that's just crossed my mind that might possibly help those still struggling -
I also noticed that the remote seemed to die after setting up the IR to control the TV.
Message posted on 03 Dec 2022 02:37 PM
I now have two remotes bought from Amazon that are working fine. No issues for 5 days now.
Message posted on 03 Dec 2022 03:43 PM
I wish I had seen these posts before ordering my Stream. It arrived today, and guess what? The remote is playing up already. No amount of trying the tips provided in earlier posts make any difference. I have called Sky and told them I wish to cancel my contract under the cooling off rules.
Message posted on 03 Dec 2022 03:54 PM
Sky Glass TV frozen connecting remote
Got Skyglass TV stuck connecting remote, pressed 1&3 to connect, but it's frozen with We are currently connecting your remote, I've tried switching TV off for 10 mins unpluggin and comes back on remote stuck and same message coming up
