Discussion topic: Stream remote completely unresponsive
Message posted on 21 Nov 2022 07:21 PM
Re: Stream remote completely unresponsive
Message posted on 21 Nov 2022 07:24 PM - last edited: 21 Nov 2022 07:26 PM
@Edro - this is a community forum, so its rare for Sky employees to comment / help. You'd need to call them to arrange a replacement.
In the meantime grabbing both ends of the remote and giving it a twist - not hard enough to break it but enough so it creaks a little has fixed 'dead' remotes for myself and lots of others. If you do it somewhere dark, then you can see the backlight come on if it springs to life as you twist. Please let us know if it works or not as it may help others with the same issue.
Message posted on 21 Nov 2022 08:38 PM
Same problem for me with two sky stream remotes. Both would eventually come to life after taking batteries out or replacing the batteries but both are completely dead now. Twisting or changing batteries doesn't help.
Sky have ordered replacements but still waiting for them to arrive.
I took one to bits to see it there was a loose connection causing the problem. The batteries are connected via a spring contact which could be temporarily disconnected by twisting the remote which might explain why twisting the remote works for some people.
Message posted on 22 Nov 2022 12:37 AM
Had exactly the same issue with my remote. Won't work out of the boa and therefore cannot set up stream (stuck on the "continue" button). Poor show for a brand new item. Having only read a few posts, it looks like there is a major fault with remotes. Begging to doubt if I should have gone from sky q to sky stream. Are they really this unreliable (and doesn't the customer "own" the sky steam device/remote - unlike sky q)
Message posted on 22 Nov 2022 10:31 AM
Got the glass tv and puck this morning. Main remote worked fine but puck remote wasn't. Worked out that it's the battery compartment. I just took a pair of tweezers and stretched the negative terminal springs a bit. Working fine now. Hope this helps.
Message posted on 22 Nov 2022 11:57 AM
The sad thing about all this for Sky is that Stream is actually very good, the remote is putting everyone off, they need to fix and admit the issue asap before stream gets an even worst name.
Message posted on 22 Nov 2022 12:53 PM
Amazingly the remote twisting solution worked. In my entire life i have never been sent anything where the solution to a problem is to 'twist it violently' but if it works, it works
Message posted on 22 Nov 2022 02:21 PM
So, I've been less stressed about this because nearly all the time I use my Harmony remote. I only need to resort to the Sky remote for voice searches. However, it must be half a dozen times now I've gone to use it and it hasn't worked. Some random combination of taking the batteries out and replacing, twisting and resetting has always, in the end, got it working again but this clearly is not satisfactory!
Is there a web page where we can add ourselves to the, presumably long, list of afected customers, so we get a replacement, if that is what's needed, or do we have to call Sky?
Sky Stream and 2nd puck, LG OLED65G2, Yamaha RX-A3060 plus Harmony Elite and Harmony 900 controlling the 2 pucks.
Message posted on 22 Nov 2022 02:27 PM
Every get some tweezers and pull out the + positive spring to make a better connection, so far this has kept my remote working for the longest period of time, we cannot keep twisting it until it breaks.
Sky this design is not on, battery connections should stick to the standard way, these way was never broken and been used for probably over 50 years, it does not need springs both ends.
Message posted on 23 Nov 2022 09:08 AM
Had sky stream two weeks and my remote has stopped working twice despite changing batteries.
My mothers had it one week and the same thing happened with her remote.
what exactly is sky doing about this other than saying the right teams are looking into it?
Message posted on 23 Nov 2022 09:13 AM
@Abi264 Sky have acknowledged the problem and are 'working on a fix' but whether that will be via a software update (who knows when!) or actual updated hardware remains to be seen. From comments on here it seems there may just be a 'bad batch' of remotes, given that the same remote has been working mostly fine with Glass for the last year or so. The problem only seems to have arisen alongside the launch of the Stream service.
Message posted on 23 Nov 2022 09:18 AM
I was told by Sky tech support that the problem was a bad batch of remotes, the problem is now fixed and they have ordered new remotes for me. However, that was last week and they have still not arrived so don't know if they will work or have the same problem.
Message posted on 23 Nov 2022 09:36 AM
@sewell can you tell us exactly the date sky admitted to you there was a known bad batch? Because anyone receiving a new sky stream puck and remote after that date will have a legitimate case with trading standards as sky will have been knowingly shipping defective product.
Message posted on 23 Nov 2022 10:49 AM
I was told on Sun 20th that there was a known problem. I spoke with them again today. The tech support tried to get my Sky Q remote working with the puck by pressing 4&6 until the remote flashes to reset the remote, then pressing 7&9 until it flashes to put the remote in IR mode. But this did not work for me. I suspect it's because my remotes are the original Sky Q remote and only the newer models can control the Sky stream puck.
Message posted on 23 Nov 2022 10:52 AM
I was also told that because I have subscribed to sky whole house I can stream sky services through my Xbox or PlayStation which would at least give me access to TV.
They also refunded the cost of the service for the days I am without the service.
