Discussion topic: Soundbox bluetooth
Message posted on 31 Mar 2021 06:27 PM
Soundbox bluetooth
Hi. I have a sky soundbox. It used to be that you press the input button twice around Bluetooth and the box would say 'Bluetooth discovery mode'. You then pair your device and away you go. This isn't happening anymore, I am not getting to discovery mode. Can someone help?
Message posted on 31 Mar 2021 07:06 PM - last edited: 31 Mar 2021 07:16 PM
Re: Soundbox bluetooth
Hi @DC11111111
Does it still say "Bluetooth" as you go through the options ? If so you need to unpair the device that is paired with it.
Once unpaired you should then be offered discovery mode again.
Edit : You may also be able to clear the Soundbox Bluetooth settings by holding in the input button (2nd from the left) on the actual soundbox- for 5/6 seconds
If you are struggling to unpair it - just restart the soundbox as described here
https://www.sky.com/help/diagnostics/sky-soundbox/soundbox-standby-unresponsive
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
