Discussion topic: Sky soundbox has stopped working
Message posted on 30 Mar 2020 03:43 PM
Sky soundbox does not produce sound from HDMI, optical or Bluetooth channels. It does still “talk” ie announces the input source chosen, but does not produce any sound from any input source. It has been working fine up to this point, but has suddenly stopped working. I have tried re-booting it by switching off at the mains but to no avail. I had to reboot the Sky Q box this morning since it wasn’t responding - I think it may have just received a software update but not sure about that.
Message posted on 30 Mar 2020 08:32 PM
This is now resolved. Both Q box and soundbox were rebooted and the volume of the soundbox turned up - it seemed to have been set at a minimum level and turning it up solved the issue....
Message posted on 31 Mar 2021 03:45 PM
Re: Sky soundbox has stopped working
I have had the same problem today. No sound through the box. In the past 20 minutes I'm recieving no picture. Neither of the remotes are operating the box but the light does flash when you press the buttons on the box.
Message posted on 31 Mar 2021 04:13 PM
Hi @RPETRIE
These are the steps I would follow
Check both HDMI cables are in firmly and if you have any spares - try those
Power off at the mains for a minute and then power back on
Try a different HDMI port on your TV just in case that's the problem
Try the full reset process as described in the link below for "unresponsive"
https://www.sky.com/help/diagnostics/sky-soundbox/sky-soundbox-different-problem
Other than that, if you bought it from Sky and it's not too old, see if they will help with a warranty exchange (certainly if it's less than 2 years old)
hope one of these helps
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
