9
This discussion topic is read only This discussion topic has been answered Discussion topic: Skyglass Puck issue
This message was authored by: 14pg
Skyglass Puck issue
One of two pucks regularly fails to switch on. I have updated the software and this was ok for a couple of weeks but I am having the same issue again. I originally asked for a replacement that was refused. I cannot continue with this issue and demand a replacement.
Avatar for 14pg
Level 3 icon
This message was authored by: 14pg Answer
Re: Skyglass Puck issue
Will do as sooon as I have an answer. I will post the outcome
Locked
This message was authored by: Joe-Bow
@14pg Do a search through the forum.  It's an ongoing issue.  You'll find a bunch of things to try to get it working for you, but my advice would be to hardwire where you can as Puck Wi-Fi performance is pretty awful for many.
Avatar for 14pg
Level 3 icon
My Puck is hard wired.
This message was authored by: fizzdisco
@14pg
If I were you I'd be calling Sky and demanding a replacement puck and a refund for the Whole Home subscription due to them not providing you with equipment capable enough of using the service.
The pucks in their current form are far too unstable for many people.
Avatar for 14pg
Level 3 icon
Thank you
@14pg  Sadly you will have to grin and bare it, or pursue them until they replace it.
Does it turn on sometimes or is it always ?
Or you could try re-pairing your remote on the puck to see if that changes anything.
https://www.sky.com/help/articles/your-sky-glass-remote#need-a-hand
Sadly I had the same issue and gave up in the end and cancelled whole home, may re-look at it when it's more stable.
Avatar for 14pg
Level 3 icon
Thank you a replacement is the only solution else I will have to cancel glass and go back to Q.
@14pg  Keep us updated be interested to see if they replace it and it improves, if that's the case I may do the same thing as my Puck was literally awful.
Avatar for 14pg
Level 3 icon
Avatar for 14pg
Level 3 icon
Sky sending replacement puck tomorrow.
Locked
