This discussion topic is read only Discussion topic: Sky versus nowtv broadband
This message was authored by: StevieG51
This may be a stupid question, but I'll ask it any way.
I presently have broadband supplied by Nowtv which is a subsidiary of S?ky and it intermittently loses signal, but quite regularly.  A broadband speed check shows my supplier to be Sky.
If I change supplier and go directly to Sky will I get the same problems or an improved service ??
Locked
Re: Sky versus nowtv broadband
@StevieG51
Likely to be exactly the same.
If your issue is with a faulty line you will take that with you no matter which ISP you go to.
If your issue is with the WiFi that the router produces, Sky will be the same as they use the same hardware however other ISPs may be better for you on that front.
I am NOT a Sky Employee
Locked
