Discussion topic: Sky q mini will not connect to my tv
Message posted on 17 Jun 2021 02:20 PM
A few days ago the tv in my kitchen reported 'no connection' which means it was failing to connect to the sky q mini. That mini is in turn connected to a booster and then to my main sky q box.
I have done the usual and reset all the connections and all seemed to connect to the main box. Green lights everywhere but still no connection to the kitchen TV.
I am a Sky broadband customer.
Any solutions confer immediate sainthood on the provider!
Message posted on 17 Jun 2021 02:34 PM
Re: Sky q mini will not connect to my tv
hi @greenjanner can I just check is it the TV itself saying no connection or the SKY Q Mini giving an image with it saying no connection ?
Message posted on 17 Jun 2021 02:54 PM
The TV says 'no connection'
Message posted on 17 Jun 2021 02:57 PM
hi @greenjanner in which case 2 things to try
- A different HDMI Cable
- Resetting the video resolution on the mini - once you are confident it is on (green light) Press Home 1 0 8 0 Home
Message posted on 17 Jun 2021 04:55 PM
@nigea99 .
I will try a new hdmi cable first. In terms of the booster alteration where would I do that? In Settings on my main Sky Q box?
Message posted on 20 Jun 2021 06:46 PM
New HDMIcable did not do the trick.
What now.
Message posted on 20 Jun 2021 06:48 PM
Is your TV actually set to show the input/source that your Sky Q box is connected to? Have you cycled through the inputs using your TV's remote control?
@greenjanner The TV is on the correct External input?
Message posted on 20 Jun 2021 06:49 PM
Yes. No problem there?
Message posted on 20 Jun 2021 06:51 PM
Checked that again. All correct as far as the TV is concerned. Why would that change in a few minutes?
Message posted on 20 Jun 2021 06:52 PM
@greenjanner Are you able to test the mini on a different TV?
Message posted on 20 Jun 2021 06:59 PM
Hi @greenjanner did you try the Home 1 0 8 0 Home reset of the video resolution ?
Message posted on 21 Jun 2021 12:12 PM
No, because I don't know how to do it!
Message posted on 21 Jun 2021 12:13 PM
Not really but why should that suddenly stop working? It turns on and off alright
Message posted on 21 Jun 2021 12:27 PM
Could the TV be faulty, not necessarily the SkyQ box?
