Discussion topic: Sky Q Wifi booster
Message posted on 21 Jun 2021 04:09 PM
Sky Q Wifi booster
I am installing a Garden Office and will need wifi in there. A Sky booster has been suggested - is this any good and what is the maximum distance it can be from my hub?
Message posted on 21 Jun 2021 04:11 PM - last edited: 21 Jun 2021 04:12 PM
Re: Sky Q Wifi booster
Sky are under no obligation to supply a booster to facilitate connection outside the main dwelling, either for Q television or more general WiFi. You'd almost certainly be better off with ethernet or Powerline networking, with an ethernet switch and access point at the far end.
Message posted on 21 Jun 2021 05:44 PM
Message posted on 21 Jun 2021 05:54 PM - last edited: 21 Jun 2021 05:54 PM
Either a cabled connection using ethernet or Powerline, as suggested above, or more exotic solutions such as point-to-point wireless bridging. It's not the job of an ISP to sort such things out: their remit typically ends either within range of the router (on a standard contract) or within the walls of the main dwelling if you've opted for an add-on such as the Sky 'Broadband Boost' or BT 'Halo' products.
