Discussion topic: Sky+ planner has been wiped
This message was authored by HJ81 This message was authored by: HJ81
I clicked into the Planner this evening to find every tab empty, except Purchased.  Will a rebuild restore the recordings and scheduled recordings?
Locked
Re: Sky+ planner has been wiped
It is worth a try as there isn't anything else that you can try.
HJ81
The Planner rebuild did not restore my recordings, which is extremely disappointing.  It would be helpful to get an explanation as to why this happened in the first place as I only seem to be able to get automated help which keeps directing me  to either the Planner rebuild or a full system rebuild which would have wiped the planner anyway, so I didn't even try that as the rest of the system is fine.
This message was authored by Mark39 This message was authored by: Mark39
Hard disk corruption or failure of some sort. It's uncommon in Sky boxes, but can happen with any hard disk installation, which is why, in computer installations,  it's always sensible to make backups.
Locked
