Discussion topic: Channel 5 No sseries links
This message was authored by BeattieEdwards This message was authored by: BeattieEdwards
Help! New Sky+ black/silver box (not Q) All channels play fine but C5 simply will not offer series links in the epg. Did a planner reset/rebuild and Sky themselves sent down a software  update but no joy. It's only C5, does anyone have any clue? It's most odd!
Locked
This message was authored by oj01 This message was authored by: oj01
Re: Channel 5 No sseries links
@BeattieEdwards Is it all C5 shows or just one in particular? (I set a Series Link for The Drowning - Mon 9pm earlier today so I know that works)
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
BeattieEdwards
Gets stranger, that program actually worked and offered a series link! Until then I would have said it was all programs (certainly  all I had tried!) so  I went through trying loads of random shows and only about 5% on C5 will give series links.  Thanks for the reply.
@BeattieEdwards Just as a thought (can't check on mine right now), go forward through the days for C5 and see if everything is populated on the EPG right up to next Thursday. As most series links would be weekly whereas The Drowning is on consequetive days.
BeattieEdwards
Yes everything is there on EPG. Cheers
Locked
