This discussion topic is read only Discussion topic: Sky Q mini set up connection issues
This message was authored by: Jess25
I have just received a sky Q mini box for us to set up upstairs. I have tried connecting it on step 2 to our main Sky Q box which is in the living room downstairs but it keeps saying unsuccessful connection. Is there anything we can do to fix this or do we need Sky Q booster? Also how do we obtain a Sky Q booster and are they free? Thanks
Locked
This message was authored by: NickNewark
Re: Sky Q mini set up connection issues
Avatar for Jess25
Hi @NickNewark, thanks for answering. I have tried the troubleshooting etc and it still isn't working
Hi @Jess25
Any chance you can try temporarily moving it closer to the main Q box to set it up .
Avatar for Jess25
Hi @oldfella not without connecting it to the TV the main box is already connected to
Assume this has a spare HDMI input @Jess25
Then yes try that.
Hi @Jess25
Assuming you get it connected near the main Q box when you move it to its proper location,  reboot the main Q box and wait until this is back up and fully running before you power on the mini.
Avatar for Jess25
Hi @oldfella, I have connected it to the main TV and tried connecting it next to the Sky Q main box but it is still saying unsucessful connection. Is there anything else I can do or do I need to get someone to come out and have a look at it?
Hi @Jess25
Are you carrying out Network Reset on the mini?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect to main Q box by pressing the WPS button on the main box (not the mini)
Locked
