This discussion topic is read only Discussion topic: Sky Q Mini box keeps freezing
This message was authored by: 818+823+122
I keep needed to re boot the mini box to get service
Locked
Re: Sky Q Mini box keeps freezing
Hi @818+823+122
Try a Reset Settings in the hidden menu on each box.
Start with the main Q box and then when this back up and fully running do the same with the mini
After the Reset you will have to re pair your Bluetooth remotes If you use them.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
Locked
