This discussion topic is read only Discussion topic: Sky Q Remote
This message was authored by: middlesex1993
Sky Q Remote
Since yesterday I have a very annoying issue. When I googled this problem, it seems I am not alone.
My Sky Q box and television are both working fine. However, since yesterday the volume and voice control no longer work on my television using my Sky Q remote. I have to use my television remote to adjust the volume.which is very annoying
I have tried the usual thing, pressing 7 and 9 simultaneously and then 1 and 3 simultaneously, but still no good. Keeps saying unsuccessful set up and try again.
I went into Set Up and went through the process of putting in make of tv etc and still no good.
I have two Sky Q remotes, the older version with no voice control and
the newer one with voice control. They both since yesterday do not work re adjusting the volume on my television,
I have also noticed as from yesterday,  I can also not put my television into stand by mode using the Sky Q remotes  and I now have to use my television remote to put my television into stand by.
.Hower both Sky Q remotes do everything else as normal and other than this my television and Sky Q remotes seem to be working as normal
Any ideas anyone. I suppose it is possible that both Sky Q remotes are faulty but that would seem unlikely.
Locked
Re: Sky Q Remote
Hi @middlesex1993
One step at a time.
If Voice control is not working it means that the Bluetooth remote is not correctly paired to the Q box.
Try new batteries and just press 1 & 3 together making sure that you are pointing the remote at the Q box.
Avatar for middlesex1993
Level 8 icon
Re: Sky Q Remote
oldfella
I have put in new batteries and pressed 1 and 3. The red light flashes. The message, Wait a minute comes up. Then says failed and retry.
I have requested a Sky engineer to come out. All very strange
Re: Sky Q Remote
@middlesex1993 wrote:
oldfella
Try rebooting the Q box @middlesex1993
And then try pairing the remote again.
Level 8 icon
Re: Sky Q Remote
oldfella
Thank you for your replies.
I should have said, I have also tried rebooting Sky Q box, as you have suggested, but that made no difference.
My initial reaction was that my Sky Q remote was faulty, but would both Sky Q remotes be faulty?  I hope it is not the Sky Q box, which they have to replace as I have so many recordings I have yet to see.
As I say other than this, the Sky Q box and my television are working as normal
All very strange.
Level 8 icon
Re: Sky Q Remote
Does anyone else have any ideas?
I have tried about six times to re set my Sky Q remote but can not do so.. I have also twice rebooted my Sky Q box but that has not helped.
My Sky Q box and television appear to be otherwise working normally.
The two things I now can NOT do is
1) Adjust the volume on my television using my Sky Q remote.
2) Put my television into stand by using my Sky Q remote.
In relation to both of the above I now have to use my television remote to do this.
Re: Sky Q Remote
As it's clear that the remotes are not paired @middlesex1993  all you can do is try periodically pairing them .
Try again in settings.
The infrared remote (non Bluetooth) does not pair to the Q box only the TV
The Bluetooth remote (with voice control) pairs to the box when first pressing 1 & 3 before it goes to the TV Settings.
As the 1&3 pairing is  by infrared make sure you point the remote at the Q box
This message was authored by: LGUser
Re: Sky Q Remote
@middlesex1993  If you still need a working remote, you can download an app for iOS or Android. I do not know the name of the Android app, but the iOS app is called Sky Remote.
Level 8 icon
Re: Sky Q Remote
oldfella and LG User.
Sadly I am not technically minded.
All I know is my Sky Q remotes are not since yesterday working properly.
Just wondering whether anyone else on this site have experienced similar issues.
Hopefully this is not a sign my Sky Q box is about to pack in.
Re: Sky Q Remote
You don't have to be technically minded to install the Sky Remote app on iOS. It's not difficult to use. I cannot speak for the Android app.
Level 8 icon
Re: Sky Q Remote
LGUser
I think I will wait for an engineer to come out before downloading apps.
I have just tried again for about the fiftieth time to do a Remote Control Set Up.
Up comes the dreaded message 'Please Wait'. Then two or three minutes later the even more dreaded message. 'Set Up Unsuccessful'
I think I shall now stop trying to do this test, as otherwise I may be looking for a new television screen.
Hopefully someone on this site has had similar issues to me.
Re: Sky Q Remote
LGUser
How are you watching TV with Sky without a woring remote? If it was me, I'd just download the app and use that to control the box.
Level 8 icon
Re: Sky Q Remote
I have a wireless set up.
My Sky tv settings show my network connection and set up is good.
I also have done a smart hub test on my television and all is good and connected
Re: Sky Q Remote
How are you using your Sky without a remote?
Level 8 icon
Re: Sky Q Remote
I can still use my Sky Q remote as normal. .For instance, I can change channels, pause and rewind, record programmes etc and go into settings.
However I can not use the Sky Q remote
1) Voice control which I liked to use and it no longer works
2) To increase or decrease the volume. I have to use my tv remote for that
3 I can no longer turn my Sky Q box on and off or put on standby using my Sky Q remote. I now have to use my tv remote for that.
All was working fine until this weekend.
The engineer will come with a new Sky Q remote but I feel it may be more complicated than that
Locked
