Discussion topic: Sky Q Mini box freezing
Message posted on 04 Aug 2021 12:05 AM
Hi. My Sky Q mini box keeps freezing. I've tried rebooting the box, rebooting the main Sky q box and the broadband router but the problem persists. Have you any advice on what to do next?
Message posted on 04 Aug 2021 06:09 AM
Re: Sky Q Mini box freezing
@Richard1709 the most likely issue is a marginal wifi connection. You can try moving the Q mini so it can get a better signal particularly if it it is under or behind the. TV or other kit.
If that doesnt help then give Sky a call,as they will either offer to send a wifi booster or arrange an engineer to come out. If they do send you a booster it should be installed halfway between the Q Mini and the main Q box (or the Sky hub if that is closer and you have Sky broadband)
Message posted on 06 Aug 2021 08:06 AM
Does anyone know how I can actually speak to someone at sky?
Message posted on 06 Aug 2021 08:29 AM - last edited: 06 Aug 2021 08:31 AM
@Richard1709 Ring them. There are inevitably waiting times but best time to ring is just after 7am or about 9pm when the lines are quieter. If you have Sky Talk or a Sky mobile dial 150 (free). Stay on the line as long as possible. Don't hang up if prompted an if asked reason for ringing say 'technical'.
Message posted on 06 Aug 2021 08:30 AM
I can't find a number for them
Message posted on 06 Aug 2021 08:35 AM
Hi @Richard1709 At the bottom of this page there is a link labelled "Contact Us" if you click on it and follow the links you should find the contact number.
Message posted on 06 Aug 2021 08:36 AM
@Richard1709 I had just edited my post above but if you don't have that option then look here https://www.sky.com/help/articles/sky-tv-not-working#need-a-hand and click on yes I still need help.
Message posted on 06 Aug 2021 12:52 PM
Hi there, I will escalate this to our community chat for you. Please look out for an email or blue chat bubble.
We look forward to speaking to you.
Lisa - Sky Tech Team Expert
