Discussion topic: Sky Q Hub security update
Message posted on 12 May 2021 02:20 PM
Hi
With the recent disclosure of new wi fi vulnerabilities, do we know when/if the sky q hub will be updated to receive this security patch?
Vulnerability here - https://www.fragattacks.com/
Message posted on 12 May 2021 06:27 PM
The Linux kernel is primarily in the whole OS type of system when it involves client-side/AP wifi vulnerabilities, not server or router and it's with certain wifi adapters. Also, the Sky router has a transparent DNS, so you cannot hijack DNS. I could go on but have read the whole advisory and it doesn't apply to Sky's routers that get firmware patched often.
Message posted on 12 May 2021 05:47 PM
Re: Sky Q Hub security update
The security vulnerabilities primarily impact client devices and most of these have been patched now, Linux systems which the Sky router is written around are not impacted.
Message posted on 12 May 2021 06:16 PM
https://www.theregister.com/2021/05/12/krack_hack_wifi/
Message posted on 12 May 2021 06:19 PM
Thanks, I hadn't seen that, I was wondering if they would have been applied to the ISP provided router yet as they tend to be notoriously slow at patching (if at all!)
Message posted on 12 May 2021 06:22 PM
Just reading in more detail, it looks like those were patches to the Linux kernel but that doesn't mean they have yet made it downstream to routers
Message posted on 12 May 2021 06:28 PM
Thanks, as long as the hubs get frequent updates I'm happy as I'm sure they will get any patches soon.
Message posted on 12 May 2021 06:53 PM
https://www.fragattacks.com/#details
Because Sky routers use a DNS transparent proxy DNS cannot be poisoned, so it does not impact Sky routers drastically or more accurately it's mitigated!
