Discussion topic: Sky Glass/Stream Homepage Problems
Message posted on 03 Feb 2023 06:58 AM
Re: Sky glass menu not working
Same problem here. Voice controlled are working but nothing else.
Re: Can’t load sky glass
Same problem as everyone else this morning 😩
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
we are having the same issue, turned tv on an off an internet, still not working, ask for sky Guide that comes up but have no sound on tv!
Message posted on 03 Feb 2023 06:59 AM
Re: Sky stream
Same problem reported up and down the country.
Try using the voice control to go to a channel.
Not ideal, but at least you can watch something.
I wish Sky would reply to one of these posts instead of locking and moving them.
if you use the voice control the TV works, just seems to e the homepage that isnt working.
Message posted on 03 Feb 2023 07:00 AM
Re: Sky glass screen stuck on sky cinema, won’t load from remote
It's like the home button has been reset to sky cinema
Use voice control and say apps, it should have the HDMI selection underneath
Re: The Home Screen on Sky Glass isn’t working
Im having the same problem..Since ive had sky glass ive had nothing but problems
Same here, I did get the tv guide by using the voice control and saying "TV Guide"
Re: Sky glass
We are having the same problem here! I used the Mic and said "tv guide, bbc iplayer" etc & it worked but I am still unable to get to the Home Screen.
same here been down over an hour so far
Same problem for me.. Feel a little reassured that its many Sky Glass users that have the same problem . Sure Sky will fix it soon. Or will they ? : )
At least I'm not alone!
I'm new to Sky (and Sky Glass) abs so far not impressed. Especially when you check service and it says there is no problem! This thread says there definitely IS.
thanks for the workaround, will give it a try
Message posted on 03 Feb 2023 07:01 AM
Sky glass
Hi I just turned my Skyglass on today and get a blue screen with the message
currently there are no programmes of this type available. Turned off at the wall, restarted and it's the same. How do I fix this please? Any ideas?
I've the same, tried the magic power off at the wall in the hope it would work and no joy!
voice command works to get the channel you want though but definitely not ideal!
