2
Discussion topic: SKY Q DOES NOT FIND PLUSNET WIFI SIGNAL
This message was authored by Harbord This message was authored by: Harbord
My mother moved house and recently installed a new SkyQ box and has taken PlusNet broadband. The Broadband wifi works perfectly on all devices - phones, computers etc. However the Sky Q box does not find it when we try and connect within Network Settings - it just does not find the PlusNet signal. Then if we try and add it as a new network there is a long list of letters such as WPA related to entering the password but we have no idea what to select. Why does SkyQ not find the PlusNet network and what can we do about it ?
This message was authored by JPR007 This message was authored by: JPR007 Answer
Re: SKY Q DOES NOT FIND PLUSNET WIFI SIGNAL
@Harbord It might be worth doing a network reset on the Sky Q box. They are known to be a bit sticky if you change your provider or even change the WiFi network, and stubbornly keep looking to find the old network and refusing a new one.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Locked
Hi @Harbord
Check the plusnet router is running a compatible 2.4ghz WiFi channel (1-12) and is in good range of the WiFi hub. Remember signal strength can be much lower to a Sky box thats tucked inside or low on a TV stand.
I am NOT a Sky Employee
Locked
