This discussion topic is read only Discussion topic: Return Labels for Sky Q
This message was authored by: davesmooth
Hi, I've recently stopped using Skq Q, and have received the box to return my Sky Q equipment. I've packaged everything up, but am unsure what labels to stick on the box.
Sky sent me two labels, but without instructions for them.
The first is a "Royal Mail Tracked 48" label, which I guess I need to stick onto the parcel(?)
The second is a "Collect+" label with a different barcode and "Shopkeeper instruction: Give To The Driver" printed on it. Do I stick this second label on the parcel too? Or keep it apart so the shopkeeper can give it to the driver?
Would welcome some clarification, thanks.
Locked
Re: Return Labels for Sky Q
@davesmooth  Each label is for a different courier so you don't need to use both.
If your using Royal mail use the Royal Mail label only.
If your using Collect+ use the collect plus label only.
Avatar for davesmooth
Thanks for confirming.
Locked
