5
This discussion topic is read only This discussion topic has been answered Discussion topic: Puck Problems
This message was authored by: PinkLouise
Puck Problems
I set up my Glass tv and puck successfully when they arrived 2 weeks ago. Tv is fine.
Puck will not now turn on. Tried powering down. No joy. Powered down and then back up whilst holding the power button and I now have a blue screen which tells me to point the Sky Q????? remote at the Sky Q????? box and hold buttons 4 and 6. Nothing happens when I do this and I cannot get past this screen.
Can anyone help please?
This message was authored by: GD1 Answer
Re: Puck Problems
Are you using the Puck remote?  Press buttons 4 & 6, you may then have to use the Glass TV remote to proceed before pairing the puck remote again.
Locked
Re: Puck Problems
This message was authored by: isaacs147
Re: Puck Problems
i had the same problem i phoned sky explained to them they tried to fix it over the phone with me least 30min could not fixit there is a solution ring sky tell them you want a NEW PUCK SENT OUT your puck is faulty sky will charge you £50, but will refund you back you can reset all day it will not workyou need a new puck
Avatar for PinkLouise
Re: Puck Problems
Yes. I am using the puck remote. Absolutely nothing happens when I press 4 and 6 together. Can't get past that.
This message was authored by: mike900
Re: Puck Problems
I had this same issue, couldn't get past the use Sky Q remote despite many resets. I then connected the puck to the router with an ethernet cable, restarted it again and it went straight into a software update and allowed me to set it up correctly.
Re: Puck Problems
Unfortunately there is no way this would be possible unless I can get a VERY long cable!!!!! Thanks though.
Locked
