Discussion topic: Pixelation on recordings mini box
Message posted on 25 Jan 2021 08:56 PM
Re: Pixelation on recordings mini box
I have had power line adapters from before having sky q never an issue, I replaced power line WiFi extenders with just power lines as I am working from home and my pc is connected to one and the other is only used when my grandson is home from the RAF for his Xbox so I really don't think it's the power lines. I have moved Amazon Alexa's away from the boxes moved my smart meter moved the hub away from the sky q box but still makes. I difference
Message posted on 25 Jan 2021 10:52 PM
Yep another disatisfied customer. Started nov mini pixelating numerous phone calls to sky, new minibox, messed with loads of settings still same. Tried powerline adaptors, hard wire and wireless. Engineer fitted a booster Saturday and now on wifi. After me fitting it he litterally ran to his van and drove off . He couldnt have got to end of street and it started again of course couldnt ring him to get him back as number witheld. Thinking of complaing to ofcom
Message posted on 25 Jan 2021 10:55 PM
Ant138
I have just the same problem had everything changed except hub, played recording on mini box pixelates and mini boxes loose connection quite often.
Message posted on 25 Jan 2021 11:01 PM - last edited: 25 Jan 2021 11:02 PM
Pixelation is ridiculous tonight on the master bedroom mini. Almost unwatchable.
All other WiFi devices turned off and rebooted router and Sky Q boxes and it still doing it.
This is a major problem now but who can be bothered phoning up to be dragged around the house changing settings and rebooting stuff for the hundredth time!?
Message posted on 25 Jan 2021 11:07 PM
I don't know what's worse the pixels or trying to work out what the hell it is !.
Message posted on 25 Jan 2021 11:12 PM
Hi
Just to let you know my mini box is the same also I have connection problems too.
Had everything replaced except hub and booster fitted.
It is very annoying.
Message posted on 26 Jan 2021 10:33 AM
I cannot believe how frustrating it is trying to talk to Sky about any issues!
Thought i'd give them a call this morning as my main box has started pixelating on live TV so I suspect an alignment issue with the dish. I think this is a seperate issue to the mini box pixelation.
The guy proceeded to drag me around the house taking photos of all my equipment.
Apparently my router is too close to the wall and a photo frame.
I cannot have my main Sky box in a glass fronted cabinet (where its been for God knows how many years and worked flawlessly). He wanted me to move all my equipment so its out in the open and away from other electrical devices, including a TV!
All my issues are suddenly related to WiFi signal interference.
Even when I pushed him on the fact that live TV doesn't use the WiFi he insisted it did.
So I have to remodel my house to accommodate Sky TV - great!
In the end I just hung up on him although I am no further forward now!
Sorry but just needed to vent!
Message posted on 26 Jan 2021 10:37 AM
Message posted on 26 Jan 2021 10:43 AM
It's crazy isn't it! All they want to do is pass the blame for issues back onto the customer.
I don't usually lose my rag with people over the phone as they are just doing their job however we hear the same script over and over again.
After pointing him to this thread I even got the standard "This is the first I have heard of an issue with the Sky mini's" and the classic "I have the same setup at home and haven't experience any issues"
Message posted on 26 Jan 2021 10:59 AM
Hi @Anthonyh1976 Have you tried changing the video output from the mini box to 1080i?
Message posted on 26 Jan 2021 11:01 AM
@Quoman7yes, the box is currently set to 1080i.
Message posted on 26 Jan 2021 11:02 AM
Thats normally selected as standard and you have to change to 1080p i did this from day one never had a problem untill recent. Some are also running UHD and it still doing it
F.y.i. I have tried having the boxes set to 1080i for a few days and 1080p for a few days- makes absolutely no difference to the pixilation issue
Message posted on 26 Jan 2021 12:36 PM
Hi
I don't mind if you want to vent.
Bare with me and I'll explain my situation.
I worked for Bt for 42 years and ended up working on major networks, when I retired Bt wouldn't give me a good deal so went to TalkTalk. I had TalkTalk broadband and old HD sky distibuted around house using rf output work very well and WiFi coverage was brilliant. Having built a new conservatory that we spend most of our time in decided it would be nice to watch HD tv on my new Samsung tv so decided to get sky Q and sky broadband, thought the mesh network (wireless access points from each mini box would be good).
Have had issues with connection problems from day one, two engineering visits all equipment changed except hub and a booster fitted, remote sky technician did a network scan and said they could see lots of network problem hence engineer visits but still the same.
My sky router is in the same position as my old TalkTalk router my main sky box is connected using Ethernet.
My biggest problem is that there is no technical information or diaganotic tools to test the mesh. Do the mini talk directly to the main box or by using the other mini boxes or hub.
If I had this I could test diagnose my own network.
I am able to stand in my house and see three of my televisions two mini boxes and the main box when I have connection problem both mini boxes go off together main keeps going, and you get no internet access until they come back.
Any help or advise from community or sky employees would be great, I am paying for my sky package + sky sports £88 a month expect it to work.
Sorry for the long post hope it all makes sense.
Message posted on 26 Jan 2021 12:50 PM
Further comment, I seem to only get Pixelation on playback on either one of my 2 Mini boxes.
Is that the most common situation? Not live shows. I have not tested if playback on a mini and recording on main box tiggers Pixelation more frequently.
Anyone done any testing to see if it load on the Q box, what about having both mini's on at the same time to they Pixelate together ?
