This discussion topic is read only Discussion topic: Pc now doesn’t work using ethernet
This message was authored by: DAvcal88
Long story short. I've upgraded from the small sky q broadband router to the new boost one. My wife's pc needs to be hardwired for work and we never had issues with the old router but the new one doesn't work. For anyone know of any issue with Ethernet cables in this router. We've had to revert back to the old router while it's sorted. Everything else connects ok to the new one
Locked
Re: Pc now doesn’t work using ethernet
What happens whan you connected by ethernet to the new router?  Any error messages?
Avatar for DAvcal88
Hi, no messages apart from it saying it cannot connect to the internet. If I click the network settings if flicks between being connected and not. If I plus back into old router it's perfect.
@DAvcal88 by default the Sky SR203 hub runs its ethernet ports at Gigabit speeds and will not connect if the cable being used does not have all 8 cores connected. Older cheap czbles often only have 4 rather than 8 cores so replacing the cable with a new one might help.
The alternative is to switch the hub to use "Fast Ethernet" which is done by typing 192.168.0.1 into a browser on a connected device. Once the hub's interface loads then click on the ethernet tab at which point you will be required to log in, the user is admin and the password is the wifi password on the hub's label. The tab has the switch for ethernet speed.
Avatar for DAvcal88
Great advise thanks. I'll give that a go
Locked
