This discussion topic is read only Discussion topic: Lagging whilst on xbox
This message was authored by: charliegreyhound
Internet Lagging whilst on xbox
Locked
Re: Lagging whilst on xbox
@charliegreyhound  If you want the forums help we need more info from you.
How are you connecting? Wifi, Ethernet?
Post your router stats also https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717
This will help identify any speed issues
This message was authored by: JPR007
@charliegreyhound Need a little bit more detail than that...
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Avatar for charliegreyhound
Yes I'm trying to log  on to get the router settings but it won't accept the username & password so it can't be my sky log in details
@charliegreyhound Depending on which router you have the username is always "admin" but password is either "sky" or if its the latest upright router (SR203) it is your WiFi SSID password👍
@charliegreyhound  You need to allow the pictures to be moderated
Locked
