Discussion topic: Issues with Sky Multi Room
Message posted on 11 Jun 2021 09:55 AM
Hi Sky team,
A few months ago a SKY engineer set up my SKY mini box upstairs for me. Unfortunately we had a power cut and the whole system has since not been working correctly. Would you be able to send an engineer to take a look please. Thank you, Nathan
Message posted on 11 Jun 2021 10:04 AM
Re: Issues with Sky Multi Room
Hi @N9than
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
Try first rebooting the main Q box and then when this is completely back up and running reboot the mini.
Message posted on 11 Jun 2021 10:05 AM
Unfortunately this is a customer forum and not Sky so all you can do is to phone them.
They are taking calls but try to discourage people from phoning so ignore all the warnings. If you have to say anything say "technical" that usually works.
@N9than wrote:Hi Sky team,
Nope - it's other customers here in the forum.
You could either call Sky for an engineer - but that might take a few weeks.
Alternatively, we could try and troubleshoot. If it was working previously then it should be ok again.
What's not working? What errors? etc?
