This discussion topic is read only Discussion topic: Hub not connecting to phone
This message was authored by: RachelNic
The internet light is not turning on on my sky hub. And I cannot connect anything to the internet.
Locked
This message was authored by: mae-3
Re: Hub not connecting to phone
@RachelNic
With the Sky App on a smartphone connected to the 4G/5G mobile network, you can perform a broadband line test and if it finds a fault you should be able to book an engineer to investigate the fault. Otherwise, you will need to contact Sky by phone for them to perform a broadband line test and allocate an engineer to investigate the fault.
Avatar for RachelNic
Thanks, that's great!
Locked
