Discussion topic: How to cancelled my tv package
Message posted on 09 Jul 2022 08:35 PM
Can I cancel only TV package
Message posted on 09 Jul 2022 08:36 PM
Re: How to cancelled my tv package
@Geo89
Once you are out of contract you need to contact Sky to reduce any part of your Sky TV package or cancel it completely giving the required notice of 31 days. If you are still in a minimum term deal you can’t usually cancel.
Select ‘Need more help’ at the bottom of the following link which will lead to a phone number. https://www.sky.com/help/articles/cancel-sky-tv
(Make sure the flag in the bottom right corner is the correct one).
UK customer ~ it should include a Message Us option between 0900-1930.
ROI customer ~ it’s only by calling or writing in.
Message posted on 09 Jul 2022 08:52 PM
@Geo89 You will need to call Sky or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
