This discussion topic is read only Discussion topic: Help to reduce my bill
This message was authored by: Janette+Pink
I'm new on here...I'm looking for advice to reduce my bill...its now £93 pm . We don't use the landlines and don't use broadband.  Always use WiFi.  Do I need the landlines??...Due to the current situation I need to get my bill down ...Please Help...Thanks
Locked
Re: Help to reduce my bill
@Janette+Pink  Best option is to give Sky a call for any deals.
You say you use wifi, so you must have broadband as you can't have wifi if you don't have a broadband connection, so if you get rid you your broadband connection then it's goodby wifi.
Wi-Fi in your home is broadband and this is delivered via your telephone line. What you can do is if you never make any phone calls via a landline phone is to call Sky and ask them to change your calls package to the Pay as you Talk one. The free number to call them on is just 150. If you are also a TV customer then ask them if there is a discount available.
Avatar for Janette+Pink
Thank you,  I'm a pensioner and don't understand how these things work. Do I need the landlines? I don't use the phone at all it's not even plugged in. Thanks
Yes, you still need the landline as that's how your wifi is delivered to your home.
But you don't need to pay for a call package if you don't use your landline phone.
Thank you I will get in touch with them
Locked
