This discussion topic is read only Discussion topic: FTTP which modem.
This message was authored by: dibdab
FTTP which modem.
Ok, FTTP looks to be availble to my property now. I have the Asus RT-AX58u router, I see sky no longer offer free calls with the current deal for FTTP so am thinking i would just need a new Modem, Not intrested in using there hub if I don't recieve free calls.
What modem would i need to buy?
Locked
Re: FTTP which modem.
@dibdab
Part of the fttp install is openreach supply a ont optical modem
So the asus will just plug directly into the port 1 on the above box
Avatar for dibdab
Level 2 icon
Ok thanks, Will i be able to see stats with this modem?
@dibdab
Not on the ont and it doesn't pass the stats onto the sky hub anyway
@dibdab
Basically what will happen you will ethernet the asus to the sky hub initially to perform firmware upgrades so that it displays client identifier (option 61). Then disconnect the sky hub and plug the asus in.
Then in the client identifier (option 61) enter
anything@skydsl|anything
And the asus will obtain the public ip and all router functions
Was that ever an option?  Sky Talk is either charged at ppm (branded as Sky Pay As You Talk) or as an allowance bundled into the subscription at an additional monthly cost (Sky Talk Evenings & Weekends Extra, Anytime Extra and and International Extra).
Telcos are typically allergic to the word 'free'.
Sky Talk Tariff Guide
Avatar for dibdab
Level 2 icon
Yes, I currently have free anytime calls with my FTTC package.
@dibdab  Presumably this was a discounted package>
Avatar for dibdab
Level 2 icon
I assume it is, my 18m contract ends in May.
@dibdabYou can check your account to see when your contract ends.
@dibdab
Stats dont exist with FTTP. The connection is either on or off. Any speed issues will either be your internal network or possible problems on Sky's end.
I am NOT a Sky Employee
Locked
