The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
16 Feb 2022 06:42 PM
Last few days cannot pause or rewind certain channels called sky went through 30 minutes of fixes engineer booked . Then yesterday it was working and now is not again anyone any experience of this?
16 Feb 2022 06:54 PM
@oldfella Thanks but did this with sky on phone , it didnt work also did a reset holding the amber button while switching power off/on
16 Feb 2022 06:51 PM
Hi @sdd123
Try a Reset Settings in the hidden menu.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
